Forum >DFRobot sensor library for Proteus?
userHead JayBirds 2022-05-28 19:09:20 14407 Views6 Replies
I am working a water quality monitoring sensor and I need to make a wiring diagram in Proteus. I cannot find the library anyone have an idea where I can find it? If not, anyone have any good software to make wiring diagram with DFRobot sensor?
2023-02-11 06:40:55
Here you can find the PH sensor library for proteus: https://www.theengineeringprojects.com/2021/10/ph-sensor-library-for-proteus.html
2023-02-11 06:40:14
2022-06-03 22:10:46
DFRobots are open-source hardware robots that can be programmed using Arduino IDE software. They have multiple sensors (including temperature, humidity, light, etc.) and are capable of performing basic functions like opening/closing doors, moving motors, turning lights off/on, raising/lowering flags, etc.
userHeadPic Musupothers
2022-06-01 01:50:26
Hi, which water sensor are you referring to specifically? PH or EC or some other sensor?
userHeadPic Winster
JayBirds wrote:
Hello, sorry for the late reply. I was looking for pH sensor, turbidity sensor, salinity sensor, dissolved oxygen sensor, and temperature sensor.
Here are the sensor type: DS18B20, DFR0300-H, SEN0169, SEN0237-A, SEN0189
2022-06-02 22:22:01
