Forum >DFR0760 Speech Synthesis V2 Not changing voices
ArduinoTroubleshooting
userHead MarkSchiff 2022-06-16 06:04:57 3209 Views7 Replies
I have an Arduino UNO connected to DFR0760 Speech Synthesis V2  that will not changing voices no matter
which voice I select to compile for.  No error messages just the same female voice.  I can change volume no problem.
Below is the program that I am using taken from V2 lib I2C example.  Please advise:
* @file i2c.ino
* @brief Control speech synthesis sensor via I2C, and synthetise speech
* @copyright   Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
* @licence     The MIT License (MIT)
* @author [fengli](li.feng@dfrobot.com)
* @version  V1.0
* @date  2020-11-6
* @get from https://www.dfrobot.com
* @url https://github.com/DFRobot/DFRobot_SpeechSynthesis_V2
#include "DFRobot_SpeechSynthesis_V2.h"
DFRobot_SpeechSynthesis_I2C ss;
 //Init speech synthesis sensor
 ss.begin();
 //Set voice volume to 5
 //ss.setVolume(5);
 ss.setSoundType(ss.MALE1);
 //Set playback speed to 5
 //ss.setSpeed(5);
 //Set tone to 5
 //ss.setTone(5);
 //For English, speak word
 ss.setEnglishPron(ss.WORD);
 ss.speak(F("She sells seashells by the seashore"));
 ss.speak(F("Hello, I'm Speech Synthesis module"));
 ss.speak(F("a b c d e f g"));
 /*Use text control identifier*/
 //Voice volume identifier
 //ss.speak(F("[v3]Hello [v8]world"));
 //Word Pronounce mode identifier
 //ss.speak(F("[h1]Hello [h2]world"));
2024-01-09 14:48:55
It's been 1-½ years since MarkSchif contacted tech support about this issue. Has there been any progress getting us the voices that were promised when we bought this product? I'm extremely disappointed in the quality of this product's firmware.
userHeadPic Lynn.Hansen
xingzhao.zhu wrote:
The R&D department has conducted tests on this module and found that incorporating various voice lines significantly compromises its pronunciation clarity and accuracy. Therefore, they concluded that this feature would not be added to the module.
Best Regards
2024-01-12 23:40:25
2023-09-16 18:46:55
Is there a planned update so support changing to male voice?
userHeadPic Stephen.Ventriglia
2023-07-13 07:21:15
I bought this module and connected to the arduino. I have tried the above code, but there's no audio output…….also the code is successfully being uploaded in the arduino without any errors.The only issue is, there's no speech or voice output from the dfr0760 module………can anyone help me out with this?
userHeadPic abhishek.reddy
jenna wrote:
Hi!
It is recommended that you refer to the wiki and try the I2C communication of the module.
https://wiki.dfrobot.com/Gravity_Speech_Synthesis_Module_V2_SKU_DFR0760
1. switch to I2C
2.connection
VCC---5V
GND---GND
SCL(Blue vire)---SCL
SDA(GREEN wire)---SDA
3.upload the example
2023-07-14 02:14:35
2023-07-10 09:16:56
Just purchased and all seems good so far….with this exception. Is this fixed yet?
userHeadPic darobins
2022-06-24 09:24:58
On 06/22/2022 I contacted Tech Support with a copy of the DFR0760 not changing voices and got the following response:
*************************Hi, Thank you for contacting DFRobot Technical Support team. Sorry, our V2 library file has not yet added the code related to the speaker
 and tone, but we will continue to update it later.
Okay, I am very happy at this time with the quick Tech Support response and information. .
userHeadPic MarkSchiff
