Forum >Acrylic Case for Raspberry Pi CM4 Antenna 'port'
General Raspberry Pi
userHead JohnMinson 2022-06-16 06:06:46 1253 Views2 Replies
Does the Acrylic Case with Heatsink for Raspberry Pi CM4 IoT Router Carrier Board Mini have a ‘port’ that an external antenna can be connected to after it (the antenna) has been connected to the cm4 ? Acrylic Case with Heatsink for Raspberry Pi CM4 IoT Router Carrier Board Mini
2022-11-15 04:14:41
Long time lurker of this sub and I finally got around to building my own. This build was heavily inspired by this minimal cyberdeck by nearphuture using the SmartiPi touch 2.
Instead of using the SmartiPi touch 2 base, I made my own base out of acrylic.
Here is a list of the main components used:Raspberry Pi 4 (4gb)
Raspberry Pi 7" touch screen
SmartiPi touch 2 case
GoPro mounting hardware
Cheap 60% keyboard with WOB pbt keycaps
Charmast power bank
Usb-c power cable with on/off switch
Speaker w/ 3.5mm omegle.2yu.co jack
I learned alot https://omegle.love throughout this process and I'm excited to share my first build here
userHeadPic BremdanJohnso
2022-11-12 11:04:30
Yes
userHeadPic GregGeiger
