Forum >DFR0558
ArduinoTroubleshooting
DFR0558
userHead ErkanGovce 2022-06-23 02:40:09 1145 Views4 Replies
Greetings, I need to make changes to the necessary code to run dfr0558 with arduino mega pro mini. arduino pro mini d20 works via d21 pins but i can't receive data
error : class DFRobot_MAX31855' has no member named 'scan'
2023-02-07 07:26:13
Hi there, I'm getting the same issue using a Arduino UNO, any suggestions?
userHeadPic Terry.Keenan
2023-01-17 22:55:00
Hi!
Sorry, please use the board in the compatibility table. This appears to be caused by an incompatibility between the code and the board.
userHeadPic jenna
