Forum >DfRobot pH Sensor Raspberry with ADC ADS1115
userHead AnilC. 2022-07-05 03:00:40 1788 Views2 Replies
Hello Guys,
i Try to Connect my pH Sensor on my raspPi 3B+.
So i Need to install ADS1115 driver:
i tried this on with  following link  https://wiki.dfrobot.com/Gravity__I2C_ADS1115_16-Bit_ADC_Module_Arduino_%26_Raspberry_Pi_Compatible__SKU__DFR0553
suddenly the Library/Software driver ( https://github.com/DFRobot/DFRobot_ADS1115/tree/master/RaspberryPi)  for RaspPi do not work
i tried install driver with Terminal ( as u See on the Page).
but this failed aswell, because anything missing on the file
so i guess i need to do this Step to connect my pH Sensor to ne raspberry.
2.: After that, How i can use my pH Sensor?
All i found are codes for arduino
maybe u can help me.
thanks a lot and sorry for my bad english
2022-07-05 03:14:37
Sorry forgot second picture
userHeadPic AnilC.
