Forum >DFRobot_HX711_I2C connect to MKR1010
userHead jeroendegroote 2022-07-12 03:32:45 1392 Views1 Replies
Dear,
I am struggling to connect my DFrobot HX711 to a MKR1010 via I2C. I am following the guidelines documented there; https://wiki.dfrobot.com/HX711_Weight_Sensor_Kit_SKU_KIT0176
This describes the process for implementing the gravity I2C 1kg weight sensor kit (KIT0176). This is the exact kit I bought. When running the example sketch ‘getCalibration’, I don not succeed in compiling it for an MKR1010, nor for an Arduino Uno.
i get the following error:
Arduino: 1.8.19 (Windows 10), Board: "Arduino MKR WiFi 1010"
In file included from C:\Users\jerdgroo\Documents\Arduino\libraries\DFRobot_HX711_I2C\examples\readWeight\readWeight.ino:13:0:
C:\Users\jerdgroo\Documents\Arduino\libraries\DFRobot_HX711_I2C/DFRobot_HX711_I2C.h:26:33: error: expected ',' before 'sensor'
#define HX711_I2C_ADDR  (0x64)  sensor IIC address*/
C:\Users\jerdgroo\Documents\Arduino\libraries\DFRobot_HX711_I2C/DFRobot_HX711_I2C.h:48:60: note: in expansion of macro 'HX711_I2C_ADDR'
  DFRobot_HX711_I2C(TwoWire * pWire = &Wire,uint8_t addr = HX711_I2C_ADDR);
exit status 1
Error compiling for board Arduino MKR WiFi 1010.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
As far as my understanding goes, my best guess is that something is wrong with setting up the I2C address at the start of the sketch. I did not change anything in the example sketch. However, I am unsure if this could be why the sketch does not compile. Could someone point out what the potential solution could be?
Thanks in advance!!
Jeroen
