Forum >DFR0282 Beetle Max Pin A0 input
Troubleshooting
userHead AllenPitts 2022-08-02 11:13:42 868 Views1 Replies
Hello Dfrobot Forum,
Using a 555 timer to light LEDs controlled by a Beetle.
The 555 timer puts out a 7.9 volt signal. The max
input that the A0 pin on the Beetle will tolerate
has been researched.
But the datasheets don't make it clear whether
the max input is 5 v or 8v.
What is the maximum voltage pin A0 will take
on the Beetle DFR0282?
Thanks.
Allen Pitts
Dallas TX
2022-08-09 22:50:50
Hi, The maximum input voltage that can be detected by the A0 interface is 5V
userHeadPic Winster
