Forum >URM08-RS485 Modbus
TroubleshootingArduino
URM08-RS485 Modbus
userHead ThijsH 2022-08-04 00:21:33 996 Views2 Replies
Is the URM08-RS485 sensor modbus correct working?
If I send a HOLDING_REGISTER 2 distance I get always the same response
11 03 00 02 00 01 27 5a  -→ 11 03 02 01 11 b8 1b
and with HOLDING_REGISTER 3  temperature
11 03 00 03 00 01 76 9a -→ 11 03 02 01 11 b8 1b 00 00 00 00 00 0e c6 00 01 02 02 00 00…. up to 255 bytes
Do I need different register?
2022-08-05 23:26:20
Thanks.
Got it working. Only the distance with register 01
userHeadPic ThijsH
Larum wrote:
Hi ThijsH,
Can you explain how you got the sensor to work? Or how you determined that you had to use register 01 instead of 02?
Much appreciated
2023-12-21 09:31:01
