Forum >Huskylens power supply overheat both i2c or usb
userHead PakornPoonsawat 2022-08-04 21:05:02 1177 Views2 Replies
I can earlier supply 5 vdc to i2c port and it worked fine for days.
Now Huskylens consumes more current on both i2c or usb and
make it overheat and is not functioning anymore.
No short circuit when measure. Anyway to fix it or any precaution
not to happen again[I have another one].
2022-08-09 19:54:09
Hi, What is the current status of your Huskylens? Black screen or can't power on? Can it be used if it is powered by USB?
userHeadPic Winster
PakornPoonsawat wrote:
Hi, I found out that breadboard buck converter 12 to 5v. gave 10v. to Husky
after use it for a while. So it happens to destroy Husky regulator?
I change buck and series 3A. fuse before supply to Husky and fuse is not burnt out.
Both ways to supply Husky have same behavior[heat the port] and not power the
module at all.
2022-08-09 20:37:26
