Forum >Arduino Leonardo 2WD miniQ Simulink/Mathlab problem
We purchased twenty-four of the 2WD miniQ DFrobots to program in Simulink. When I try to set up the Mathlab support package for Arduino, I always get a problem in that it won't connect to the robot. I also have a problem when I tried to download a program on to the robot via Simulink. When I try to download the program it states: that the port that the robot is plugged into is not available. When I try different ports I get the same result. Can anyone please help me?
2017-11-17 00:47:16 Is the ports in device manager detected that Leonardo is connected? and you have to wait a few seconds to see if the port is lost from the device manager
robert.chen
2017-11-09 14:28:50 We purchased twenty-four of the 2WD miniQ DFrobots to program in Simulink. When I try to set up the Mathlab support package for Arduino, I always get a problem in that it won't connect to the robot. I also have a problem when I tried to download a program on to the robot via Simulink. When I try to download the program it states: that the port that the robot is plugged into is not available. When I try different ports I get the same result. Can anyone please help me?
leroyroberts
