Forum >Cannot upload sketch to DFRduino nano
TroubleshootingArduino
userHead HuyTrinh 2022-08-18 02:52:03 1191 Views2 Replies
I previously succeed in uploading the code to DFRDuino Nano (Arduino Nano Compatible) (with wrong digital pins) but after changing pin I cannot upload it again.
From the [document][1], I changed back the pins 0 (RX) and 1 (TX) are used for serial communication.
In arduino ide (1.8.19), I choosed **board: Arduino Nano** and **Processor: ATmega328P(Old Bootloader)**
The error:
avrdude: Version 6.3-20190619
        Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
        Copyright (c) 2007-2014 Joerg Wunsch
        System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
        Using Port                    : COM3
        Using Programmer              : arduino
        Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
An error occurred while uploading the sketch
I have reset both the board and computer but without luck.
Any idea how to solve it ?
 [1]: https://wiki.dfrobot.com/Arduino_Nano_328__SKU__DFR0010_
2022-10-07 21:43:26
I found if you select TOOLS>Processor>"old bootloader" seems to work. Strangely I only have this problem on some nanos others are fine. Guess that is just the chip selection they use.
userHeadPic JamesWalter
2022-08-23 23:27:13
Hi, When a device is connected to the TXRX interface, the upload will fail due to a communication conflict. Please upload code first and then connect TXRX
userHeadPic Winster
