Forum >Beetle ESP32 - C3 default board config
userHead unlogisch04 2022-08-21 14:53:55 1401 Views1 Replies
In the Wiki in “The first time to use”  https://wiki.dfrobot.com/SKU_DFR0868_Beetle_ESP32_C3#target_4
it is written that you should enable “USB CDC on Boot”
The boards.txt the CDC on Boot is not on by default
https://github.com/espressif/arduino-esp32/blob/master/boards.txt#L6469
https://github.com/espressif/arduino-esp32/blob/master/boards.txt#L6478-L6481
Whats the reason for that?
On platformio i have to define additional compile flags to make it work.
There are not lot of boards to compare too:
- lolin_c3_mini
- Adafruit QT Py ESP32-C3
2023-03-07 01:21:07
For Beetle ESP32 - C3(DFR0868), if you do not enable USB CDC, the serial port is 20 and 21, instead of 0 and 1.
userHeadPic NeloKin
