Forum >Battery level firebeetle esp32
userHead EckhardtGolo 2022-08-21 15:05:13 2605 Views4 Replies
Hi, I just started using a firebeetle esp32 and searched in this forum for information how to read the level of a attached battery. I didn't understand correctly: is it necessary to solder something on the board and/or build a circuit or is it possible to directly measure battery level with code?
Thx for your help!
2022-11-30 16:02:55
thanks <a href="http://casscolab.com/">environmental consulting </a>
userHeadPic desnis.watson
2022-11-30 15:35:35
Is this the only way to read battery level?
userHeadPic Jeroen.Tuinstra
2022-08-24 13:18:19
Thx!
userHeadPic EckhardtGolo
2022-08-23 23:29:34
Since the relationship between battery voltage and remaining capacity is not linear, it is recommended to use a fuel gauge to measure battery capacity.
https://www.dfrobot.com/product-1734.html
userHeadPic Winster
