Forum >Help Multiple Gravity DHT20 Sensors and addressing in code?
userHead mikegold 2022-08-23 07:58:47 1573 Views1 Replies
Hi everyone,
My goal is one Arduino board with multiple Temperature/Humidity sensors e.g. a DHT20
The code to address a single sensor is at https://wiki.dfrobot.com/Gravity_I2C_Temperature_Humidity_Sensor_DHT20_SKU_SEN0497
https://telechargerhappymod.com/
Apologies but my two specific Questions: may be considered pretty basic- Very new to this and getting started -
In terms of cabling two or more sensors to the arduino board - I can't see it in my head - obviously one can be connected but can multiple? Am I missing something very basic? The wiki shows the cable diagram for one sensor being connected - can I just use another set of analogue ports for a second sensor? But I would quickly run out of ports - so how deal with (extreme example) 10 sensors as an example?
And then in terms of code -
#include <DFRobot_DHT20.h>
 * @brief Construct the function
 * @param pWire IC bus pointer object and construction device, can both pass or not pass parameters, Wire in default.
 * @param address Chip IIC address, 0x38 in default. */
DFRobot_DHT20 dht20; void setup(){
For one sensor - the declared sensor “dht20” is addressable. For multiple sensors I would need to declare multiple DFRobot_DHT20    which I can do from a code perspective but they will not be connected to the actual multiple sensors. Is the solution to pass @param pWire IC bus pointer object and construction device  and if so how is this done? Is there a tutorial I have not found?
Regards
2022-11-04 17:41:36
Hi! Please use with this product:
https://www.dfrobot.com/product-1780.html
On the same I2C port, DFRobot Gravity: I2C Multiplexer solves the address conflict and enables the normal communication with multiple same-address I2C devices.
userHeadPic jenna
