Forum >Any alternative to the DFRobot SEN0395 mmwave radar?
How to select
userHead HumeleJotesane 2022-09-01 20:29:18 3765 Views9 Replies
Trying to build a mmwave presence detector and this module (recommended) seems to be in very high demand because I can't find it anywhere without some crazy markup. Is there an alternative to this sensor that will do the same thing? Thanks.
2023-02-26 07:04:33
I have parsed four out of the eight potential targets by turning on the uart target output switch. They can be viewed on the internal webserver because of how noisy they are. ​<a href="https://techemirate.com/workday-for-pc-windows-mac/">.</a>
userHeadPic Henry.cavill
2023-02-26 06:59:27
I have parsed four out of the eight potential targets by turning on the uart target output switch. They can be viewed on the internal webserver because of how noisy they are. ​https://techemirate.com/workday-for-pc-windows-mac/
2023-02-26 06:58:30
I have parsed four out of the eight potential targets by turning on the uart target output switch. They can be viewed on the internal webserver because of how noisy they are[URL="https://techemirate.com/workday-for-pc-windows-mac/"].[/URL]
2023-02-26 02:29:25
You can try Microwave Radar Motion Sensor Module (RCWL-0516).
2023-02-25 22:45:27
Visit the <a href="https://eggy-car.com/">eggy car</a> page if you're debating whether to switch the sort of radar you're now utilizing or what kind of radar you should replace. You can ask questions and speak with <a href="https://ovo-game.com/">ovo game</a> specialists using this website.
userHeadPic Sykes.Timothy
2023-02-21 17:07:25
You can get SEN0395 here.
https://www.dfrobot.com/product-2282.html
Also, you can try this mmWave sensor :SEN0521
https://www.dfrobot.com/product-2585.html
Hope it can help.
userHeadPic NeloKin
2022-12-16 01:30:06
With the enablement of the uart_target_output switch I have parsed four (4) of the eight (8) possible targets. These are viewable on the internal webserver since they are very noisy. This opens up new possibilities in both tuning and automations.
** WARNING ** leaving a browser sitting open on the ESP web_server with all 16 target (dist/SNR) https://echat.date updating realtime may cause your ESP to reboot after a few minutes. Please use the web_server for tuning purposes only. Since the target distand/SNR are internal, Home Assistant will be fine.
num_targets however is not internal. You may wish to set it that way or exclude it from logger;HA configuration.yaml:
logbook:  exclude:    entity_globs:      - sensor.num_targets*
userHeadPic HumeleJotesane
Tim.Cornillaud wrote:
I'm very confused by your comment.  What does it have to do with your post at 2022-09-01 12:29:18?
2023-02-21 14:40:41
2022-11-20 11:13:12
Same impression from my side!Not available at all - but another question - may be you can answer:I want to use the module with an ESP32 but could not find the library "DFRobot_mmWave_Radar.h”  as mentioned in DFROBOTs docu and my forum post https://www.dfrobot.com/forum/topic/316523
userHeadPic Uwe.Raatz
