Forum >A DF Robot router board that supports OpenWRT
userHead yadavrekha 2022-09-06 01:52:24 796 Views1 Replies
With the DF Robot router board for Raspberry CM4, I am at a loss. I have a CM4 version of this board sans wifi, and it has two interfaces: WAN and LAN. I looked at a few tutorials on how to manage VLANs on YouTube and other sources, but to my surprise, there is no "Switch" option for VLANs when I install the most recent DF Robot OpenWRT build for their board. And this is where I start to become lost... The goal is straightforward. I want to set up and configure fundamental VLANS using OpenWRT with various IP ranges, but there are some limitations on the firewall's side.
2023-04-20 10:50:29
Hi yadavrekha!
Can you elaborate more about what do you wanna accomplish with the board? Maybe i can help.
Also, just to let you know, i just finished building lastest OpenWRT image for the DFROBOT Carrier BOARD.
If you are interested in creating a custom image, or need custom packages to be installed, i created a tutorial that can may help, link for the tutorial: https://viniciuspaes.com/raspberry-pi/how-to-build-custom-openwrt-image-raspberry-pi-router/
The images files that i created are also available in my gdrive: https://drive.google.com/drive/folders/1ETjAfQOTZthzX6gUCI4hoGncGX8F7RNg?usp=sharing
Best Regards,
Vinicius
userHeadPic viniciuspaes
