Forum >undefined reference to `esp_now_..
userHead Pierre-YvesDUSSAIX 2022-09-12 00:16:36 4115 Views2 Replies
Hello
I can't compile my sketch or other sketchs found on internet that use ESPNOW on your Firebeetle ESP8266. My sketch is running well on an ESP32 from Azdelivery.
I got this error :
<command-line>:0:19: warning: missing whitespace after the macro name [enabled by default]
/private/var/folders/ml/fhx2h4td5bn6jsqjc2w8n1v00000gn/T/arduino-sketch-254AFB23495B17BEC9862AC214E42AE6/sketch/sketch_sep11b.ino.cpp.o:(.text.setup+0x8c): undefined reference to `esp_now_init()'
/private/var/folders/ml/fhx2h4td5bn6jsqjc2w8n1v00000gn/T/arduino-sketch-254AFB23495B17BEC9862AC214E42AE6/sketch/sketch_sep11b.ino.cpp.o:(.text.setup+0x90): undefined reference to `esp_now_set_self_role(unsigned char)'
All ESPNOW directives I used are “undefined reference”.
I try to add  "-lespnow" to the compiler.c.elf.libs line in my ~/.platformio/packages/framework-arduinoespressif8266/platform.txt as suggested by some.
What is wrong?
Regards
BTW I can't send a file.
2022-09-26 17:29:02
Hi! You can try this board link:
http://arduino.esp8266.com/stable/package_esp8266com_index.json
userHeadPic jenna
2022-09-24 01:43:08
Hello, I have already reported your question to the product manager. I will notify you as soon as possible if there is a reply.
userHeadPic jenna
