Forum >Please update OpenWRT image for CM4 IoT Router Broad Mini
userHead FrantisekZustin 2022-09-13 14:15:48 2824 Views3 Replies
Hello DFRobot developers,
there is a new version of OpenWRT (22.03.0), which is finally working for my CM4 IoT Router Broad Mini.
I cannot find a solution how to install all packages and drivers into the official version from OpenWRT.
So please, update your image to working with this new version. Image with the older versions don't work for me at all (board not supported).
2023-04-20 10:37:53
Hi FrantisekZustin, good afternoon!
I just published an step by step tutorial to how to build a custom image of OpenWRT to DFROBOT Router Board Mini.
You can check the tutorial in this link: https://viniciuspaes.com/raspberry-pi/how-to-build-custom-openwrt-image-raspberry-pi-router/
Or you can go and download the latest versions that i created (v22.03.4): https://drive.google.com/drive/folders/1ETjAfQOTZthzX6gUCI4hoGncGX8F7RNg?usp=sharing
userHeadPic viniciuspaes
2022-09-13 21:54:05
Hey Frantise, what did you do to get 22.03.0 onto the router? Was it an upgrade from an earlier version?
userHeadPic simeoncran
viniciuspaes wrote:
Hi Simeoncran,
I made a custom OpenWRT image for the DFROBOT Router Board. Stored The image files in my google drive, you can check by this link: <a href="https://drive.google.com/drive/folders/1ETjAfQOTZthzX6gUCI4hoGncGX8F7RNg?usp=sharing">Download OpenWRT image custom build for DFROBOT CM4 Router Board</a>
2023-04-20 10:40:53
