Forum >Huskylens object classification switched in code
userHead TonyEllis 2022-09-13 08:08:30 1544 Views1 Replies
With Huskylens, can “object classification” be switched in code (Arduino) like all the other functions - i.e. go from “face recognition” to “object classification” with a few lines of code?
If so, could you please show the code required?
Many thanks for any help, it is much appreciated.
Tony
2022-09-13 13:17:13
This is using the Arduino API:
#include "HUSKYLENS.h"                            //Import the required libraries
HUSKYLENS huskylens;                              //Create a new Huskeylens object
int ID1 = 1;
  Serial.begin(115200);                                       //Start serial communication
  Wire.begin();                                               //Connect to Huskylens
  while (!huskylens.begin(Wire))
      Serial.println(F("Begin failed!"));
      Serial.println(F("1.Please recheck the \"Protocol Type\" in HUSKYLENS (General Settings>>Protocol Type>>I2C)"));
      Serial.println(F("2.Please recheck the connection."));
      delay(100);
  huskylens.writeAlgorithm(ALGORITHM_OBJECT_CLASSIFICATION);
Later, when you want facial recognition, you would do something like the following line:
huskylens.writeAlgorithm(ALGORITHM_FACE_RECOGNITION);
It is very easy to use the Arduino API.
userHeadPic embeddedprogrammer
