Forum >SEN0257 What type of pressure does it measure?
General Gravity
userHead RaulSantamaria 2022-09-17 07:35:44 1108 Views1 Replies
When the sensor is placed at the bottom of a tank, does the sensor measure the absolute pressure (Hydrostatic pressure: pressure under the water surface + atmospheric pressure: pressure above the water surface) or does it measure gauge pressure (only hydrostatic pressure)?
2023-02-24 22:28:48
Gravity: Analog Water Pressure Sensor(SKU:SEN0257) is used to test the absolute pressure in water.
Hope it can help.
userHeadPic NeloKin
