Forum >HuskyLens API
HUSKYLENSGeneral
HuskyLens API
userHead markiemoosle 2022-09-29 09:21:20 2309 Views4 Replies
Can the ‘learn’ button be pro grammatically triggered via software with the API? As in if I can parse the data and see a face, is there a way to make the unit ‘learn’ the face in software?
I can get it to work as long as I physically use the button and then checked in software for learned blocks,but…
2022-10-23 20:39:43
Is this due to the wrong API  or anything else? What do the experts suggest doing now?
Thanks in advance.
https://pintvideodownloader.com/pinterest-story-downloader/
userHeadPic Jijo.Ken
2022-09-30 21:32:19
Just answering my own questions here :-(
the only software learn functionality is the ‘writeLearn(int)’ API function, but it only applies to the object recognition. So the answer to my original post is…
No.
userHeadPic markiemoosle
2022-09-29 11:29:28
Im fearing that this could have been a rhetorical question to myself. I don’t think it programmatically supports the ‘learn’ of pushing the physical button. I think I’m going to have to switch over to the m5stack V2 AI camera as this has a much better source programming interface. Shame as I do like the Huskycam unit for its speed and display, I just think it does fall down on its API.
2022-09-29 09:23:53
