Forum >lower inpout voltage on Sen0104 (Mini touch kit)
userHead Account cancelled 2017-10-31 02:55:36 1842 Views1 Replies
Hello
I see the Sen0104 work at 3.3volt to 5.0 volt , but on the TTP223-BA6 datasheet I see this component can work at 3.0 volt.
So my question is: it's possible to change the minimum work voltage at 3.0 volt instead of 3.3 volt ?
Thank you
2017-11-04 01:52:45 Based on the schematic and the datasheet, 3.0V is workable userHeadPic robert.chen
