Forum >ESP32 with Gravity TDS Sensor connect to firebase database
userHead wanqodir 2022-10-26 12:34:53 2480 Views1 Replies
hi everybody. I'm making my first real-time monitoring system using esp32 and the Gravity Analog TDS Sensor which will be connected to the firebase database.
can anyone help me in coding esp32 with Analog TDS Sensor to firebase database?
Thank you..
Here the sensors I used:
2022-10-27 20:06:17
Because of the esp32 chip analog input accuracy and voltage issues, please use with this module.
Gravity: I2C ADS1115 16-bit ADC Module (Arduino & Raspberry Pi Compatible) - DFRobot : https://www.dfrobot.com/product-1730.html
userHeadPic jenna
