Forum >Nodes on Raspberry pi 2
General Raspberry Pi
userHead SnowranCruzick 2022-11-12 01:33:00 1028 Views1 Replies
Been in Bitcoin for a while but mainly as a hodler and now I want to take the next step (running a node)
I really want to run a bitcoin node and I happen to have 2 old raspberry pis that I am not using at all. One of them is a raspberry pi 2 and the other one is a 3.
Since I read everywhere that the recommended raspberry pi should be a 4... Can I still run nodes with the 2 and 3? (So I can at least get some kind of use out of them. I am not going to be using them for anything else anyways) Or is it not technically feasible?
2022-12-21 02:19:52
Just putting the response from @Prashant Pathak above here:
Download latest nodejs build for Raspberry Pi:
wget https://nodejs.org/download/release/v0.10.0/node-v0.10.0-linux-arm-pi.tar.gz
Unpack files in local directory:
cd /usr/local sudo tar xzvf ~/node-v0.10.0-linux-arm-pi.tar.gz --strip=1
That's it. You can confirm it's there by checking the node version with:
node -v
and:
npm -v
The actual url to get the files for node will change as the version changes, you can always see the list of files available for download here: http://nodejs.org/download/
All these instructions came from: http://www.robert-drummond.com/2015/01/08/server-side-javascript-on-a-raspberry-pi-how-to-install-node-js-2/ https://e-chats.com/omegle / https://echat.date
userHeadPic SnowranCruzick
