Forum >Overlord Pro Cooling Fan issues.
3D PrintingGeneral
userHead Account cancelled 2017-11-02 07:35:19 3657 Views1 Replies
It just wont start for some reason and i've seen alot of others has the same problem but no one seems to know why, the fan works but the CF Connector doesnt or something.
2017-11-03 23:07:22 Hi
The vertical fan which connected to "Fan" pin is keeping working when it power the printer up, while two leaning fans connected to CFan is working sometimes during the printing, you can take a look during the printing process, if it not working at any time , you can switch two pins and see if two leaning fans working when power it up, then you can decide if any fan is faulty or not.
userHeadPic robert.chen
