Forum >FireBeetle ESP32-E does not connect on Arduino IDE
userHead goldman 2022-12-14 11:57:38 794 Views2 Replies
Hello! Recently bought FireBeetle ESP32-E from here https://aliexpress.ru/item/1005002724454945.html
I have setting up my Arduino IDE as it is described here https://wiki.dfrobot.com/FireBeetle_Board_ESP32_E_SKU_DFR0654
But it does not connect, I have tried different cables, windows and linux OS, even different computers but it does not work. I checked my arduino nano and it works properly.
Do you have any ideas how to get it worked?
[spoiler]
$ lsplug
USB 4-2  [0bda:0411] Realtek Semiconductor Corp. Hub
USB 3-2  [0bda:5411] Realtek Semiconductor Corp. RTS5411 Hub
USB 3-2.3 [1a86:7522] QinHeng Electronics CH340 serial converter
USB 3-2.1 [0a81:0101] Chesen Electronics Corp. Keyboard
USB 7-1  [1a40:0801] Terminus Technology Inc. USB 2.0 Hub
USB 3-3  [0489:e0d8] Foxconn / Hon Hai Wireless_Device [000000000]
USB 1-4  [048d:c102] Integrated Technology Express, Inc. ITE Device(8910)
USB 3-2.2 [0461:4e2a] Primax Electronics, Ltd USB Optical Mouse
[/spoiler]
2023-02-04 20:31:45
I have the same issue.  I have an iMac with M1 silicon running MacOS Ventura 13.1 running the Arduino IDE 2.02, and have connected to the FireBeetle ESP32-E with a USB-C cable.  I'm trying to FLASH the blink program, but it always times-out waiting for packet header.  I recognize the serial port, and have reduced the upload speed to 115K, but I always get the timeout.
I've tried pressing the rst button during “connecting” and this does not work.  I have tried two different FireBeetle ESP32-E devices, and both fail.
What do I need to do to program this device?
userHeadPic jkardach
2023-01-03 19:22:45
You can try to press and hold the RST button, while the IDE shows connecting……
And if it still not works, then it might be the hardware failure.
userHeadPic YeezB
