Forum >Read Led Charge
Read Led Charge
userHead Rob_20065 2022-12-22 04:37:23 1612 Views3 Replies
How can I access information from the Charge Led.
To know if it is on, off or flashing.
What is the reading pin?
Thank you
2023-02-21 18:48:32
It is D9/2 according to the datasheet.
userHeadPic NeloKin
2022-12-24 04:56:25
Thanks for the replyYes, I can see that. I would like which is the GPIO to read the state of the LED.I am using Arduino IDE in programming.
Thank you
userHeadPic Rob_20065
2022-12-22 20:54:11 https://wiki.dfrobot.com/FireBeetle_Board_ESP32_E_SKU_DFR0654 Charging Indicator: red LED for indicating charging status: 1. Off when fully charged or not charged; 2. On when charging; 3. Quick flash when powered by USB, and no battery connected. userHeadPic Bob.Zhuang
