Forum >Unable to power using battery pack
userHead Squirrel.Ras 2022-12-26 01:09:47 285 Views1 Replies
I have realised that once I upload code onto my board, I am then unable to use a battery pack to power the board. When ai plug in the battery, no lights come on.
When ai plugged in the battery before uploading a code, the blue light came on.
Any help?
2022-12-26 02:45:33
Hi all, just solved the issue. The code I uploaded makes it go into deep sleep. When I then plug the battery it is unable to wake up. So I force it to wake up by setting the blue led light to high by adding a single line of code in the setup function. Works like a charm now.
userHeadPic Squirrel.Ras
