Laser Sensor SNE0366 & arduino MKR wifi 1010 no go
Hello
There was a working board in the lab with the laser sensor working. The arduino code was long gone.
I had to get it working again, so I used the code from this page:
https://wiki.dfrobot.com/Infrared_Laser_Distance_Sensor_50m_80m_SKU_SEN0366
The board will not work now and the laser sensor does not even turn on.
This is the start of the arduino code from the above page:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2,3);//Define software serial, 3 is TX, 2 is RX
char buff[4]={0x80,0x06,0x03,0x77};
unsigned char data[11]={0};
{ Serial.begin(115200);
mySerial.begin(9600);
Now the MKR wifi 1010 does not need the SoftwareSerial.h apparently, and it does not compile code with it. One has to use the internal serial, or Serial1 as they call it.
So the above code becomes:
Serial1.begin(9600);
*similar for all other references to myserial, as it is now removed.
The problem is that now, there is nothing coming from the sensor, there are no values and as mentioned the sensor doesn't even turn on.
Need to mention that the board is inside a box, so nobody messed with it, I uploaded the arduino code as I found it, it didn't work, I changed the myserial thing to the Serial1 thing, and now nothing works.
Any suggestions greatly appreciated !
thank you all
The full code is:
Serial1.print(buff);
while(1)
if(Serial1.available()>0)//Determine whether there is data to read on the serial
delay(50);
for(int i=0;i<11;i++)
data[i]=Serial1.read();
unsigned char Check=0;
for(int i=0;i<10;i++)
Check=Check+data[i];
Check=~Check+1;
if(data[10]==Check)
if(data[3]=='E'&&data[4]=='R'&&data[5]=='R')
Serial.println("Out of range");
else
float distance=0;
distance=(data[3]-0x30)*100+(data[4]-0x30)*10+(data[5]-0x30)*1+(data[7]-0x30)*0.1+(data[8]-0x30)*0.01+(data[9]-0x30)*0.001;
Serial.print("Distance = ");
Serial.print(distance,3);
Serial.println(" M");
else
Serial.println("Invalid Data!");
delay(20);
You have to define the pins of Serial1 when you use .begin() function.
The pins should follow the datasheet of the board, sorry we do not have this board so you have to check yourself.
Modify the codes and wiring according to the datasheet, then try again.
Hope it can work.
