Forum >A01NYUB with Mycodo on a Raspberry pi 2B
General Raspberry Pi
userHead Panos.Takis 2023-01-10 09:45:56 1004 Views2 Replies
Hello!
1) I am trying to connect a A01NYUB ultrasonic distance sensor, to a raspberry pi running mycodo, so I can monitor and control the water tank level.
As I have no previous experience with electronics and coding and having no idea where to ask I thought I should give it a try here.
If this is not the place, please let me know where should I look/ask.
2) Is there a way to connect (combine) more than 1 UART sensors on a raspberry pi in one pair of pins? I thought of using a UART to usb converter to overcome this issue but I will still need drivers and coding.
Thanks!
2023-11-24 09:45:41
The solution I got for 2) is a “Gravity: I2C to Dual UART Module”.  https://www.dfrobot.com/product-2001.html
Thanx for the help
userHeadPic Panos.Takis
2023-01-13 05:46:09
WALKAROUND
For the moment I found a way to get measurements from the sensor. I used the BASH Command input
First you need to make some changes.
Go to directory
“/home/username/DFRobot_RaspberryPi_A02YYUW/examples/” (replace username with username you chose when installing Raspbian)
Make a safe copy of the original file “demo_get_distance.py”
Cp demo_get_distance.py demo_get_distance.py.bkp
then
Sudo nano demo_get_distance.py
Delete all and Paste the following
# -*- coding:utf-8 -*-
  @file demo_get_distance.py
  @brief Get ranging data.
  @n Connect board with raspberryPi.
  @n --------------------------------------------
  @n sensor pin |         raspberry pi          |
  @n     VCC    |            5V/3V3             |
  @n     GND    |             GND               |
  @n     RX     |          (BCM)14 TX           |
  @n     TX     |          (BCM)15 RX           |
  @n
  @Copyright   Copyright (c) 2010 DFRobot Co.Ltd (https://www.dfrobot.com)
  @license     The MIT License (MIT)
  @author [Arya](xue.peng@dfrobot.com)
  @version  V1.0
  @date  2019-8-31
  @url https://github.com/DFRobot/DFRobot_RaspberryPi_A02YYUW
import sys
import os
import time
sys.path.append(os.path.dirname(os.path.dirname(os.path.realpath(__file__))))
from DFRobot_RaspberryPi_A02YYUW import DFRobot_A02_Distance as Board
board = Board()
def print_distance(dis):
  if board.last_operate_status == board.STA_OK:
    print("%d" %dis)
  elif board.last_operate_status == board.STA_ERR_CHECKSUM:
    print("ERROR")
  elif board.last_operate_status == board.STA_ERR_SERIAL:
    print("Serial open failed!")
  elif board.last_operate_status == board.STA_ERR_CHECK_OUT_LIMIT:
    print("Above the upper limit: %d" %dis)
  elif board.last_operate_status == board.STA_ERR_CHECK_LOW_LIMIT:
    print("Below the lower limit: %d" %dis)
  elif board.last_operate_status == board.STA_ERR_DATA:
    print("No data!")
if __name__ == "__main__":
  #Minimum ranging threshold: 0mm
  dis_min = 0
  #Highest ranging threshold: 4500mm
  dis_max = 4500
  board.set_dis_range(dis_min, dis_max)
  distance = board.getDistance()
  print_distance(distance)
Save and exit
These changes return one single value so mycodo can use store and display it.
Create a bash file in home directory for example. I named it A01NYUB.sh
Open it and Pastethe following:
#!/bin/bash
python3 /home/username/DFRobot_RaspberryPi_A02YYUW/examples/demo_get_distance.py
save and close
from a termina run
chmod +x /home/username/A01NYUB.sh
And last step
on mycodo go to  Setup/Input
Choose from the dropdown menu “Linux Bash Command: Return Value [Mycodo]”
In the window that opens
In Options section in the Command box paste
./A01NYUB.sh
In Custom options in the box User enter username you chose when installing Raspbian
And next to it in Current working directory type
/home/username/
click save ad then click close
Activate the input you just added
Done
