Forum >Accelerometer - LIS2DH - impact recognition and logging?
I have recently bought a Gravity: I2C Triple Axis Accelerometer - LIS2DH. I intend to use it to sense the vibrations on an arm when playing tennis.
- How can I effectively log the data? (200+ shots)- Is there a way I can only record data for an amount of time after an impact is detected (tennis ball hitting the strings)? 2023-02-21 01:10:19
NeloKin
I personally suggest you write a program on your PC, which receive the data from the serial port and save it in a text doc. So that you can log your data.
For your second requirement, you can set a threshold that will only be triggered if the tennis ball hits the strings. Then, your software can start recording data for some time and wait for the next hit.
Robotics ProjectsRobotics TutorialsRobotics ProductsView Arduino ProductsMore Arduino Related ProjectsArduino TutorialsMore Gravity ProjectsView Gravity Products
