Forum >URM37 V4.0 FOV(Field of View)
I am planning to use URM37 V4.0 for an application but I need to know about the FOV( Field of View) of the sensor. Is it good as I have to mount them on the side of my car so I need a good field of view so that limited number of sensors are required also tell me if there is another sonar or ultrasonic sensor which has a good field of view.
Thank you.
Thank you.
2017-12-26 02:02:55 If you want to add a ultrasonic sensor on your car, I recommend the weaterh-proof ultrasonic sensor https://www.dfrobot.com/product-1503.html
robert.chen
