Forum >SKU:SEN0395: Call of readPresenceDetection blocks execution
userHead Vik.Vikarowitsch 2023-01-16 00:27:10 829 Views3 Replies
Installed product, downloaded the code and run it on Arduino UNO.
The call readPresenceDetection blocks execution of sketch.
Any advice or information how to proceed?
2023-02-21 07:50:50
Hi Thanks for the advice.Finally figured out by debugging with println in method DFRobot_mmWave_Radar::readN
that available was false.
Finally found cold solder joints on my side.
userHeadPic Vik.Vikarowitsch
2023-02-20 23:55:39
Could you please share the screenshot of your serial monitor, and your wiring?
Also, could you please measure the GPIO2 output voltage? Do it perform normally?
userHeadPic NeloKin
