Forum >TMF8701 TOF Sensor with an ESP32-CAM board
How to selectArduino
userHead Mark.Petereit 2023-01-24 13:15:35 1099 Views1 Replies
I'm trying to use a TMF8701 TOF sensor with an ESP32-CAM board. The camera uses the default I2C pins.
How would I modify the example Arduino sketch to use alternate pins for a second I2C channel? (SDA = Pin 33, SCL = Pin 32)
2023-02-20 22:19:29
As the connection use Wire.h, you can enable the second I2C by this way.
However, you can connect these two sensors on the same I2C port, they will work together as they have different I2C addresses.
Hope it can help.
userHeadPic NeloKin
