Forum >Connect two SEN0546 to ESP8266
Troubleshooting
userHead Duarte.Cota 2023-02-03 12:44:57 330 Views3 Replies
I need to connect two SEN0546 I2C Temperature & Humidity Sensor to ESP8266.
Is this possible only by assigning a diferent address to the second? In this case what would be the address (i am using 0x40 on the first))
Thank you.
2023-02-03 12:48:14
userHeadPic Duarte.Cota
