Forum >SEN0524 Slow readings
Troubleshooting
userHead david.leitner 2023-02-03 11:05:49 355 Views3 Replies
I have a SEN0524 tof sensor, which i got working with an ESP32 via UART.
Is it normal, that the sensor value follows the distance really slow?
I takes approx 3 seconds to get the correct value, when the distance changes about 2m.
2023-03-28 11:55:03
Hello,I am working with the same sensor and I got the same problem. Were you able to fix the problem?
userHeadPic Manuel.Ratola
2023-02-03 23:55:14
Maybe i explained wrong, the refresh rate is fast.
But when the distance to measure changes fast, the data goes up or down like a ramp,
until it reachches the correct value, which takes seconds.
userHeadPic david.leitner
