Forum >LattePanda Delta 3 Benchmark Score
General LattePanda
userHead jamay.kans 2023-02-13 08:09:59 879 Views1 Replies
Looking at getting another sbc, but have not used an x86 sbc, and on the website, the Delta 3 has the score of 793, but what is this score exactly? Single core? Multi core? Gpu? Looking at the Zima board, they have a multi-score of 933, but when comparing the chips, the Lattepanda should be significantly higher, is it just from form-factor restrictions? Looking at other arm alternatives like the Khadas Vim4 show much higher (almost double) the performance.
2023-02-14 06:13:17
LP Delta 3 uses intel 10th N5015 while zima using intel 8th N3450.   I just found a good comparision between these two chips.
Here is a comprehensive comparison between these two chips:
https://www.cpu-monkey.com/en/compare_cpu-intel_celeron_n5105-1688-vs-intel_celeron_n3450-659
userHeadPic R2D2C3PO
