Issue with SEN0494 and Jetson NANO B01
I am attempting to get the SEN0494 to work with my Jetson NANO B01. I have followed the doc located here. When I attempt to install the .deb package it tells me I have the wrong core dependency. with the following error:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'nvidia-l4t-kernel' instead of './nvidia-l4t-kernel_4.9.201-tegra-32.5.0-20210115145440_arm64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nvidia-l4t-kernel : PreDepends: nvidia-l4t-core (< 32.6-0) but 32.7.3-20221122092935 is to be installed
E: Unable to correct problems, you have held broken packages.
It seems to me that the files provided are for an outdated kernal. Where can I find an up to date .deb for the current version of the kernal core? Version 32.7.3-20221122092935
