Forum >Looking for compatible motor with encoder
General Robotics
userHead Ben.Cranston 2023-02-16 18:40:54 1225 Views5 Replies
Greetings,
I have one of the Pirate kits.  I've managed to damage the plastic gears on the motors and would like to upgrade to a motor that has metal gears and an encoder.  Can you make a recommendation on one that will fit the Pirate kit form factor.  Thanks!
-Ben
2023-02-17 10:55:47
Looking further in the catalog I see https://www.dfrobot.com/product-1458.html which has an encoder..  But other than the mention of a metal shaft, there is no indication if the gears inside are plastic or metal.  Can someone confirm the construction material of the gears?  thanks.
userHeadPic Ben.Cranston
2023-02-17 00:47:26
These are the generic BO motor and wheels set. You can buy from any online/offline electronics parts shop.
https://www.amazon.in/DIGIONN-BO-MOTOR-WHEEL-YELLOW/dp/B09M42D8FB
Ben.Cranston wrote:
Thank you.  Those look exactly like the ones that came in the kit.  And based on the description given on the amazon listing, are not with metal gears nor the encoders I'm looking for.
Specifically I'm looking for compatible form factor, but with metal gears and rotary encoder.
This listing: https://wiki.dfrobot.com/Micro_DC_Motor_with_Encoder-SJ02_SKU__FIT0458 has the encoder, but no indication of the material of the gears.
Same thing for this one: https://wiki.dfrobot.com/Micro_DC_Motor_with_Encoder-SJ01_SKU__FIT0450
Unknown if the gears are metal.
2023-02-17 03:58:32
