Forum >DFPLAYER PRO Play from USB Stick
General Arduino
userHead Frank.Liessner 2023-02-24 05:59:53 574 Views2 Replies
I know I can connect the DFPLAYER PRO to my computer and copy files to it and play it. That is working fine.
Now I would like to plugin a USB Stick directly to the DFPLAYER PRO and let it play the music directly from the stick. Is that possible?
2023-02-24 14:57:25
I found a library here that refers to USB. If you can get it to work, please do share the sample code here. I am waiting for my DFPlayer in the mail. https://github.com/enjoyneering/DFPlayer/tree/main/src
userHeadPic Raza Rizvi
Frank.Liessner wrote:
Thank you, I will try it out if I can make it work. It looks like the Lib is made for the dfplayer MINI and not the PRO, but let's see.
2023-02-25 00:34:12
