Forum >I need to feed an arduino.
I'm doing a project where I have to draw power from the outlet and I'm not sure how to prevent the arduino from burning, I thought about using a relay but I'm not sure if it works for that, thanks.
2023-03-02 19:20:27
NeloKin
Yes, you can use an relay to control the arduino. However, if you use a dc power supply (9-12v), the arduino won't burn.
Hope it can help.
bidrohini.bidrohini
wrote:
2023-03-02 22:46:25 1 Replies
Does dfrobot have any Arduino compatible AC-DC adapter?
