Forum >HuskyLens memory problem
Troubleshooting
userHead Oravecz.Sándor 2023-03-01 04:18:41 452 Views2 Replies
I purchased a HuskyLens device a few days ago. I can handle it pretty well now. Unfortunately, the problem is that you forget the learned objects after a while. Sometimes after half an hour, sometimes after several hours. Even when there is power supply and even when there is no power supply.
I would like to ask for help.
2023-03-03 05:14:47
Yes, the firmware update helped.HuskyLens defaults to “0.5.1aNormal”used it.
The new working version is "0.5.1Normal"The error depended on a letter "a".Greetings
userHeadPic Oravecz.Sándor
2023-03-01 17:56:31
Generally, Gravity: Huskylens - An Easy-to-use AI Camera(SKU:SEN0305) won't forget what it learns unless you press the button on the right upside.
If your Huskylens keep forgetting what it learns without pressing the right button, please refresh the firmware, which you could find in our WIKI page.
https://wiki.dfrobot.com/HUSKYLENS_V1.0_SKU_SEN0305_SEN0336
Hope it can help.
userHeadPic NeloKin
