Forum >SEN0244 TDS Sensor compatible with AVR128db28?
Can I implement the SEN0244 TDS Sensor for a water quality detection system using the AVR128db28?
2023-03-05 01:48:10
R2D2C3PO
As long as the AVR128db28 has analog input. After reading the datasheet, the answer is yes. You can have AVR128 working with TDS sensor.
