Forum >SEN0161 Analog Ph sensor soil measurements
GravityHow to select
userHead Kerellos.Osama 2023-03-11 01:37:45 845 Views1 Replies
Can the sensor be used to measure soil ph directly by inserting into the soil after removing any hard objects that can remove damage the electrode and watering the soil? would it provide accurate readings?
2023-03-11 02:56:00
I personally used this. And as far as I know, this is for liquid only.
