Forum >How to set ranges for gyro and accel for Gravity - BMI160 6DoF IMU
userHead Mikolaj.Gra 2023-03-15 00:53:18 1152 Views1 Replies
I have Gravity - BMI160 6DoF IMU (DFRobot SEN0250). I would like to set the following parameters from the arduino ide using DFRobot_BMI160.h library:
-BMI160_ACCEL_RANGE_4G
-BMI160_ACCEL_ODR_50HZ
-BMI160_GYRO_RANGE_250_DPS
-BMI160_GYRO_ODR_50HZ
but I don't know what syntax to use to set these parameters for the sensor. Syntax “bmi160.setRanges(BMI160_ACCEL_RANGE_4G)” didn't work.
Does anyone have a solution to change the range of values?
Thanks by advance.
2023-03-15 22:02:23
For Gravity - BMI160 6DoF IMU (DFRobot SEN0250), according to the library, you may have to call this function to modify the configuration of the sensor.
userHeadPic NeloKin
