Forum >DFR0513 PPM Motor Drive Module
General Robotics
userHead Stephen.Somogyi 2023-03-14 22:46:14 776 Views2 Replies
Hi All,
I am confused with the connection Instructions for this motor control module.
I read that I can connect the module to the PPM output of my RC receiver.
There are however two channels on the module, one for each motor.
The PPM is a ONE WIRE system,
Therefore - which channel do I connect the PPM wire to?
Thanks in anticipation
Stephen
2023-03-15 01:38:19
Thanks for your reply NeloKin,
When using RC there is no code ???
userHeadPic Stephen.Somogyi
2023-03-15 00:51:50
You can use either pin as PPM signal input. Just remember to define the correct pin in your code.
userHeadPic NeloKin
