Forum >SEN0211 and esp32
GravityTroubleshooting
SEN0211 and esp32
userHead RichardDurrant 2023-04-07 11:49:37 1198 Views1 Replies
Question for your SEN0211 I am looking at usign it with a esp32, looking at you example code other than changing your “// For Arduino Zero, Due, MKR Family, ESP32, etc. 3V3 controllers, change VREF to 3.3” is there anything else that would need to be changed.. Many thanks in advance….
Richard
2023-05-11 02:47:50
Since the on-board ADC of the ESP32 is 12bit, while the most of Arduino has the 10bit ADC.
So you need to change the 1024(2^10) into the 4096(2^12) to use the SEN0211 on the ESP32
Please take a look at following picture to modify the code:
After all, SEN0211 is an analog output sensor, but the onboard ADC of ESP32 has a large offset.
So if you encounter a situation where the reading is quite different from the actual reading, it is recommended that you use an external ADC.
external ADC: https://www.dfrobot.com/product-1730.html
userHeadPic Yeez_B
