Forum >URM15 Reading Issue
Troubleshooting
URM15 Reading Issue
userHead Martin.Lallemand 2023-04-08 03:53:40 585 Views2 Replies
I have a problem with my URM15 ultrasonic sensor. I tried to communicate with the sensor and a Siemens IOT2050 using pymodbus (a Python library) through the DB9 port, but the sensor didn't send any data.
Python script (read distance value) :
client= ModbusClient(method = "rtu", port="/dev/ttyUSB0", stopbits = 1, bytesize = 8, parity = 'N', baudrate=19200)
connection = client.connect()
print(connection)
result = client.read_holding_registers(adresse = 0x05,  count =1 , unit= 0x00)
print (result)
Error :
Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 4 bytes (0 received)
The connection RS485 -→ DB9 :
RS485-A -> Pin 1
RS485-B -> Pin 2
GND -> Pin 5
VCC -> External 5V
2023-06-05 02:14:10
You can try using a different Modbus client software or tool to communicate with the URM15 sensor. This will help determine whether the problem lies with the sensor, the IOT2050 device, or the pymodbus library.
2023-06-03 02:00:20
Is this 485 sensor connected to the 485 to TTL module, first test the communication on the computer successfully?
Please check the address of the 485 module. It is recommended that you try this Python library: https://github.com/ljean/modbus-tk
For example:
master.execute(12, cst.READ_HOLDING_REGISTERS, 0, 3)
userHeadPic jenna
