Forum >How to replace cooling fan on LattePanda Delta 3?
userHead Viktor.Nikolov 2023-04-08 23:25:57 1278 Views2 Replies
Hi!
My LattePanda Delta 3 is running continuously and the colling fan worn off, it became noisy.
Is there a way to replace the Delta 3 cooling fan? I couldn't find a spare part on dfrobot.com nor on the internet. ☹️
Viktor
2023-04-15 00:35:45
Yes, it is possible to replace the cooling fan on your LattePanda Delta 3. However, since you were not able to find a spare part on the official website or the internet, you may need to consider some other options.
Firstly, you can try reaching out to the manufacturer or the distributor of the product to see if they can provide you with a replacement fan or point you in the direction of where you can get one.
If that does not work, you can consider purchasing a compatible cooling fan from a third-party seller. You will need to ensure that the replacement fan matches the specifications of the original fan in terms of size, voltage, and connector type  <a href="https://beiteck.com/sale">Apartments for sale in Dbayeh</a>
You can also consider using a universal cooling fan or a small PC fan that can be attached to the heatsink with some adhesive or zip ties. However, make sure that the fan you choose is compatible with the voltage requirements of the LattePanda Delta 3.
Lastly, you may consider upgrading to a more powerful cooling solution such as a liquid cooling system or a larger heatsink with a fan. This would require some technical expertise and may involve modifications to the LattePanda Delta 3's chassis.
userHeadPic jaackma.biden
2023-04-11 23:37:23
Please contact DFRobot to purchase the fan separately: store@dfrobot.com
userHeadPic jenna
