Forum >Arduino compiling error (not enough memory)
TroubleshootingArduino
userHead Pavlos98cy 2023-04-11 00:26:21 438 Views1 Replies
I bought the KnowFlow Basic Kit ffrom DFRobot plus temperature and turbidity sensors for my thesis "Automatic drinking water monitoring device". Also, I inserted 2 solenoid valves to control the volume of the water in a metal box (the place where I will take measurements with sensors).  I think that the code is ready (I checked each part separate) but the problem is that this KIT included an Arduino UNO and I don't have enough memory for the process.
Here are the error I see.
''Global variables use 2212 bytes (108%) of dynamic memory, leaving -164 bytes for local variables. Maximum is 2048 bytes.''
"Compilation error: data section exceeds available space in board."
My code:
#include <OneWire.h>
#include "DFRobot_EC.h"
#include <DFRobot_PH.h>
#include <EEPROM.h>
#include <Arduino.h>
#include <Wire.h>
#include <SD.h>
#include "GravityRtc.h"
#define chipSelect 7
#define EC_PIN A1  // EC sensor i/o
#define PH_PIN A1  // PH sensor i/o
// Temperature sensor i/o
int DS18S20_Pin = 2;          // DS18S20 Signal pin on digital 2
const int solenoidPinIn = 3;  // set pin number for solenoid valve 2
const int solenoidPinOut = 4; // set pin number for solenoid valve 1
// Globals
float voltage, phValue, ecValue, temperature;
OneWire ds(DS18S20_Pin);  // on digital pin 2
DFRobot_EC ec;
DFRobot_PH ph;
GravityRtc rtc;     //RTC Initialization
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
//const int chipSelect = 7;
void setup(void) {
  Serial.begin(9600);  // Baud rate: 9600
  ec.begin();
  ph.begin();
  // set pinMode
  pinMode(solenoidPinIn, OUTPUT);  // set the first valve pin as an output
  pinMode(solenoidPinOut, OUTPUT); // set the second valve pin as an output
  rtc.setup();
//Set the RTC time automatically: Calibrate RTC time by your computer time
  rtc.adjustRtc(F(__DATE__), F(__TIME__));
  //Set the RTC time manually
  //rtc.adjustRt(2017,6,19,1,12,7,0);  //Set time: 2017/6/19, Monday, 12:07:00
 // Open serial communications and wait for port to open:
  Serial.begin(9600);
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("\nInitializing SD card...");
  // On the Ethernet Shield, CS is pin 7. It's set as an output by default.
  // Note that even if it's not used as the CS pin, the hardware SS pin
  // (10 on most Arduino boards, 53 on the Mega) must be left as an output
  // or the SD library functions will not work.
  pinMode(10, OUTPUT);     // change this to 53 on a mega
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card is inserted?");
    Serial.println("* Is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    return;
  } else {
   Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.print("\nCard type: ");
  switch(card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
      break;
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
      break;
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
      break;
    default:
      Serial.println("Unknown");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    return;
  // print the type and size of the first FAT-type volume
  uint32_t volumesize;
  Serial.print("\nVolume type is FAT");
  Serial.println(volume.fatType(), DEC);
  Serial.println();
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize *= 512;                            // SD card blocks are always 512 bytes
  Serial.print("Volume size (bytes): ");
  Serial.println(volumesize);
  Serial.print("Volume size (Kbytes): ");
  volumesize /= 1024;
  Serial.print("Volume size (Mbytes): ");
  volumesize /= 1024;
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
{ // RTC loop
rtc.read();
//*************************Time********************************
  Serial.print("   Year = ");//year
  Serial.print(rtc.year);
  Serial.print("   Month = ");//month
  Serial.print(rtc.month);
  Serial.print("   Day = ");//day
  Serial.print(rtc.day);
  Serial.print("   Week = ");//week
  Serial.print(rtc.week);
  Serial.print("   Hour = ");//hour
  Serial.print(rtc.hour);
  Serial.print("   Minute = ");//minute
  Serial.print(rtc.minute);
  Serial.print("   Second = ");//second
  Serial.println(rtc.second);
  delay(1000);
  //turbidity
  int sensorValue = analogRead(A0);              // read the input on analog pin 0:
  float voltage = sensorValue * (5.0 / 1024.0);  // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
  float NTU = -1120.4 * pow(voltage, 2) + 5742.3 * voltage - 4353.8;
  Serial.print("TURBIDITY: ");
  Serial.println(NTU);  // print out the value you read:
  // Read temperature
  float temp = getTemp();
  Serial.print("Temperature: ");
  Serial.print(temp, 2);
  Serial.println(" °C");
  // Read EC
  voltage = analogRead(EC_PIN) / 1024.0 * 5000;  // read the voltage
  ecValue = ec.readEC(voltage, temp);            // convert voltage to EC with temperature compensation
  Serial.print("EC: ");
  Serial.print(ecValue, 2);
  Serial.println(" ms/cm");
  // EC calibration process by Serial CMD
  ec.calibration(voltage, temp);
    static unsigned long timepoint = millis();
    if (millis() - timepoint > 1000U) {  //time interval: 1s
      voltage = analogRead(PH_PIN) / 1024.0 * 5000;  // read the voltage
      phValue = ph.readPH(voltage, temperature);     // convert voltage to pH with temperature compensation
      Serial.print("pH:");
      Serial.println(phValue, 2);
      Serial.print("\n");
    ph.calibration(voltage, temperature);  // calibration process by Serail CMD
  // pH sensor i/o
  const int analogInPin = A3;
  int sensorValuePH = analogRead(analogInPin);
  float voltagePH = sensorValuePH * (5.0 / 1024.0);
  float pHValue = 7 - (voltagePH - 2.5) / 0.18;  // convert voltage to pH
  delay(2000);  // Wait for 2 second
float getTemp() {
  // Returns the temperature from one DS18S20 in DEG Celsius
  byte data[12];
  byte addr[8];
  if (!ds.search(addr)) {
    // No more sensors on chain, reset search
    ds.reset_search();
    return -1000;
  if (OneWire::crc8(addr, 7) != addr[7]) {
    Serial.println("CRC is not valid!");
    return -1000;
  if (addr[0] != 0x10 && addr[0] != 0x28) {
    Serial.print("Device is not recognized");
    return -1000;
  ds.reset();
  ds.select(addr);
  ds.write(0x44, 1);  // start conversion, with parasite power on at the end
  byte present = ds.reset();
  ds.select(addr);
  ds.write(0xBE);  // Read Scratchpad
  for (int i = 0; i < 9; i++) {  // we need 9 bytes
    data[i] = ds.read();
  ds.reset_search();
  byte MSB = data[1];
  byte LSB = data[0];
  float tempRead = ((MSB << 8) | LSB);  // using two's complement
  float TemperatureSum = tempRead / 16;
  return TemperatureSum;
  // open solenoid valves
  digitalWrite(solenoidPinOut, HIGH);
  digitalWrite(solenoidPinIn, HIGH);
  delay(1000);
  // close solenoid 1 in 10 seconds
  digitalWrite(solenoidPinOut, LOW);
  delay(10000);
  // close solenoid 2 in 20 seconds (gemisma doxiou)
  digitalWrite(solenoidPinIn, LOW);
  delay(20000);
  // wait 4 minutes
  delay(240000);
  delay(1000);
  delay(10000);
  // close solenoid 2 in 5 seconds
  delay(5000);
  // wait 8 hours
  delay(2880000);
I checked OUTPUT for each part separately and the memory is almost full just by RTC, microSD module, pH and EC sensors. So generally memory is full even from the main KIT parts. What should I do? Shouldn't the company had to provide a stronger Arduino board for this kind of projects, like Arduino Mega? please give me some advices  of some tips to decrease the memory which I spend in this program. I inlcude my code. Thank you in advance for the help!
2023-04-11 22:10:25
Pls check this forum: https://forum.arduino.cc/t/data-section-exceeds-available-space-in-board/873305/5
You can also consider replacing the controller with larger memory, such as mega2560:https://www.dfrobot.com/product-655.html
userHeadPic jenna
